Nizzed »
https://forums.nicoclub.com/nizzed-u265642.html
Wed Jun 22, 2016 5:52 am
Hey folks,
I can't find any info on having success solving the step motor issue associated with this code P1778 and with the 2007-09 Nissan Altima 2.5. I know they have Jatco CVT transmission JE0F10A. Did this thread die out? Are you still dealing with this or how did you resolve it?
I'm dealing with this issue right now and some others associated with this CVT, simultaneously, like the whining bearing.
Glad to know what the code points to: mechanical. So something in the pressure system malfunctioning??? Does everyone know about the in-line CVT fluid filter that receives fluid after it passes through the radiator cooler? Just changed mine. Definitely clogged, and when replaced, transmission now holds (doesn't roll back) on inclines. AND, with the new fluid, the whining is gone (at least in the first 200 miles after flush.)
