Post by bassactuator » https://forums.nicoclub.com/bassactuator-u102682.html Fri Aug 01, 2008 2:50 pm
Post by jltibbs » https://forums.nicoclub.com/jltibbs-u32412.html Sat Aug 02, 2008 3:17 pm
OBD Codes.com wrote:
OBD II Code P0125
What does that mean?
This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine.Symptoms
You will likely not notice any drivability problems.Causes
A code P0125 may mean that one or more of the following has happened:
* Insufficient warm up time * Low engine coolant level * Leaking or stuck open thermostat * Faulty coolant temperature sensor
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is likely going to be the result of the above causes (faulty thermostat, faulty coolant sensor, or a low coolant level).
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
