Engine Code FAQ
Hijacker
Car: '92 240sx Convertible
'94 F-150
http://www.sportcompactcarweb....bble/
this is for all of the people out there who don't understand what a 2JZ engine really is.
I'm sure this has been posted before, but it's alway nice to have a healthy reminder for people who are in the grey about engine codes from other manufacturers like I am.
fuzion
Car: Cars.. Web/graphic design.. Yuppp
who makes 2JZ? Is it a 2 or 4 door?
Hijacker
'94 F-150
honda. it's AWD 7 door.
SeVa-S13
Car: '05 GTO 6spd
Carb'd, with 5 cams.
Hijacker
'94 F-150
http://www.autospeed.com.au/cm...=0206
actually, here's a better article (sorry dave!) It includes the Mitsu engine codes, except for the 4G94 (current 2.0L powerplant of the USDM lancers) and the new 4G69 which is the 2.0 MIVEC used on the USDM Lancer Ralliarts.
fuzion
thats gotta have close to 1500HP from 1.3 liters if it's AWD!!!!!!!!!!!!!!
Actually it is a pretty good write up, and hondas engine codes are funky
Hijacker
'94 F-150
I was trying to find the autospeed article, but realized I had the SCC article bookmarked. Then I went looking for Mitsu codes on EvoM.net and found the autospeed article. Much better.
BB Turbo
Car: 2007 Nissan Titan KC
1992 Nissan 240SX Coupe
Wasnt the 4G69 the same as the one in the FTO? Dont feel like searching at this moment.
Hijacker
'94 F-150
The G69 is a G94 block with a different deck and a MIVEC head on it. FTO's have three engine options (from what I know of) A V-6 MIVEC, a V-6 non-MIVEC, and a 1.8L I4 non-MIVEC.
Hijacker
'94 F-150
I think the code for it is 6A12 (from what I found on EvoM)
EDIT: I don't know what the A stands for. It's a common misconception to interperet the G as "Generation", but Mitsu has a D series family that stands for Diesel, so I believe the G stands for Gasoline.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The EVO still uses the 4G63 right?
Hijacker
'94 F-150
yep. Has and always will.
Onizuka
" while the SR20VE has no turbo, but uses variable valve timing. (Not all variable valve timing engines get a V, however.)"
Poor dave colman, he can never live up to my geekyness with nissan motors. The SR20VE does not use variable valve timing, it uses variable valve lift, all engines with variable valve lift have V in the engine code, all engines with variable valve timing are not indicated so in the engine code.
Hijacker
'94 F-150
dave considered the Mitsu engine codes unbreakable, when the code has never been hidden as far as i've known. then again, his article was written in '99, so back then, VVL might have been mistaken for VVT. I've been into cars for a while, but only recently have I gained knowledge as to what VVT is and how it works
SeVa-S13
Car: '05 GTO 6spd
So you're saying Nissan's Neo VVL doesn't employ VVT aswell as VVL?
Onizuka
nope, i reseached extensively the SR20VE/SR16VE/SR20VET, i even spoke to a few SR20 parts stores, the motor does not have variable valve timing, only variable valve lift. The s14/s15 SR20DET and Q45 VQ45DE both have variable valve timining, yet no V in the engine code.
SeVa-S13
Car: '05 GTO 6spd
Is there a reason for not having both Timing and Lift Variability in one head? Too expensive? Too difficult to design? Does the famed VTEC have both?
Onizuka
My guess would be production costs. On an interesting note, nissan has been developing variable crank stroke on the good ol' SR20 platform.
Hijacker
'94 F-150
variable cranke stroke? i wanna see the tech specs on that
Rifter240
Car: 1989 240 with a SBC bored .20 over
I love the look on peoples faces when i whip out Nissan engine codes...people look like your speaking greek. You could seriously pull any random combination of letters and numbers and people would believe you.
Onizuka
tenkawa_akito wrote:variable cranke stroke? i wanna see the tech specs on that
I saw some diagrams, its mind boggling
If i can find the article on the internet ill post some pictures.
Onizuka
ahh crap, i saw it in a magazine, but they want $12 for me to be able to download it, i guess your just going to have to use your imagination. :pface
http://www.sae.org/servlets/pr...-0921
SeVa-S13
Car: '05 GTO 6spd
What exactly would be the advantage of Stroke Variability? A long stroke down low for good torque delivery but lesser stroke at higher RPMs? Seeing as HP is a factor or TQ and RPMs, do they plan to compensate for the loss of effective displacement with better flow and cam characteristics later in the RPM band? :confused:
Hijacker
'94 F-150
i wanna know how they can do this without stressing the crank too much. i'm afraid a system like this will spin bearings too fast
Onizuka
It variable compression ratio actually (my bad), but it still involves an additional mechanism attached to the crank. Its really cool looking, i wish i could find some pictures for you guys.
I also belive volvo has done a system like this too.
Hijacker
'94 F-150
hmm....i'm still happy Nissan hasn't abandoned the SR platform. I'd like to see a new S16 silvia
Onizuka
Unfortunatly they have abondoned the RWD SR20, all current production SR's are transverse (either FWD or AWD).
Hijacker
'94 F-150
stupid nissan.
SeVa-S13
Car: '05 GTO 6spd
AWD ain't bad.... =\
Hijacker
'94 F-150
but it's still gonna be a transverse SR. If it were a Latteral SR with a GT-R style AWD, that would be nice
