NISTECH wrote:on your EGR it seams virtually impossible for that [engine goes faster when Barry pushes up on the diaphragm] to happen.
When opening the egr valve as your doing it creates a huge vaccum leak to the intake . . .
I have a good, spare EGR Valve on my work bench.
It has two small vacuum line metal tubes (line ‘A’- comes FROM the BPT, and is on top of the EGR Valve, and ‘B’- goes TO?? somewhere and is swaged like a metal brake line into the cast metal base of the EGR Valve assembly, and seems ALWAYS open to air flow through it)
and the EGR Valve has two medium sized hole in the cast metal base part of the EGR Valve (‘C‘- big hole for exhaust gas to go TO the adjoining air intake manifold, and ‘D’ – a bigger hole for exhaust gas to come FROM the exhaust on the other side of the engine.)
The exhaust gas is ALWAYS coming from ‘D’ and going out thru ‘B’. Sometimes the exhaust gas ALSO goes out thru ‘C’, as well as ‘B’.
When the engine is idling, and there is NO vacuum coming from the BPT via 'A', then 'D' and 'B' are the only path for the exhaust air. I. e., the exhaust comes into the EGR Valve solid metal base via 'D' and some exits out via 'B'. The EGR Valve keeps the exhaust gas from exiting out ‘C’ until the next thing happens.
When the engine is running faster, there IS vacuum from the BPT via 'A', and then the diaphragm in the EGR Valve is drawn up by the vacuum, and this opens a path for the exhaust gases to come from 'D' and pass out of ‘C’, as well as 'B'. This addition Exhaust Gas [Recirculated] [EGR] now passing by ‘C’ and into the intake manifold causes a richening of the air/fuel mixture by reducing the air [the exhaust gas that recirculates into the intake takes up some of the space that the oxygen air would use] and the compression is still maintained high because the total gas volume is the same, giving a richer fuel mixture.
Richer air/fuel mixture = cooler burning engine. A given!!
Well, Barry has the engine at idle and warmed up, and Barry pushes up on the EGR Valve diaphragm with his stubby fingers. This allows the exhaust gas to recirculate into the air intake, enrichening the air / fuel mixture while maintaining the overall volume of gases to support the compression cycle. Barry was creating a richer A / F mixture at idle, and this is not good.
What!! If you have a richer A / F mixture without adding extra fuel, and keeping the compression up, and it runs cooler, what is wrong with that picture.
OK, the problem is that it ‘reduces power’….. When the engine is just tooling around, doing its own thing at a normal cruise speed, so what if you are losing 20% power. You aren’t using it, anyways!! But when you full-throttle hit the gas pedal, the EGR Valve will lose the vacuum from the BPT and the EGR Valve will CLOSE the recirculated gas flow out of ‘C’ and into the intake. This will give you the OPTIMAL air / fuel mixture (what is it, 7.4 air to 1 fuel??) for power.
Similarly, when the engine is idling, the OPTIMAL air / fuel mixture should be the target with maximum efficient power, and the EGR Valve should close off the flow of exhaust gases to the intake manifold.
Simple??
But why did Barry’s engine go faster when he introduced exhaust gas at idle. It should have choked (flooded??) the engine.
Well, it would have shown symptoms of flooding an engine if it was at the optimal air / fuel mixture to start with. But if the car was running too lean to begin with (Why is it running lean, only the big ‘G’ mechanic in the sky would know), and the mixture was increase toward the optimal level of 7.4 to 1, then it would be expected that the engine would (slightly) increase its idle speed.
Any ways, it does show that Barry’s exhaust gas will be recirculated when the diaphragm is lifted, as we have shown by mechanically lifting the diaphragm with stubby fingers at idle. The question is, does the diaphragm ALSO lift with the vacuum from the BPT when the engine is run at about 2500-3000?? Easy to check, no problem. If it DOES NOT lift with vacuum while it does lift with stubby fingers, I have a tested EGR Valve on my work bench, ready to go in.
[[FWIW, I also have one or two functioning BPT valves, and three extra sets of AIV reeds – one cleaned pretty. available on an as needed basis. Or I could package the stuff and sent to NISTECH for him to take apart or distribute.]]
I don’t want to stop this thread without asking a question, so here it is:
Where do I connect my hand held RPM meter at the engine so I can read the RPMs when I am under the hood. Make it simple, guys, and I may have a different coil than the earlier 240SX’s.
Thanks
Barry Burneskis'94 Auto Convert 240SX S-13 KA24DE [custom leather interior, if that matters]Springfield VA
