motor is in, finally, did nothing to the trans and installed everything in order as far flywheel and clutch.
Now question is when i put in 1st gear and you move the crank it still should move freely? or lock up? i still need to finish installing the parts, but im wondering how this works or i messed something up..
thanks
Modified by Spinn3r at 11:03 AM 4/5/2009
