NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Wed Jan 07, 2004 12:58 pm
Allright! Got back to work on the CA after a long break...
Here's how it sits now:
Head off... cams removed, going to replace valve oil seals, and transfer all parts from old DET head(bad) to DE head(good)... lifters, valves, springs, cams, etc...
All accessories and brackets off the block, oil pan off. With the help of Tim we've been dousing this thing in GUNK engine bright for the last hour, and we hosed out the coolant system (all the passages, and the block drain hole) You should have seen the funky colored water that came out of there... green, yellow, brown, orange:eek:
Everything shines pretty, and the whole crank/pistons/etc rotate 10x better than before. After we rinsed the gunk off (as per the directions on the can) we applied a ton of wd40 to lubricate everything, and remove all water from everywhere in the engine to prevent rust.
I am quite frankly amazed with the results of the thorough cleaning. It looks to be an almost new engine! The casting marks on the cylinder walls look almost new!:D I was told it was a 30k kilometer motor, and I'm starting to believe it...
What's next:Dissassemble the head, and clean in a similar fashion. Replace the valve oil seals, and reassemble it.
Buy a gasket set from Nissan with all new gaskets (including head gasket) and begin to reassemble the motor.
Water Pump- New from Nissan.
QUESTIONS:1.) should I go ahead and do the rings? Its an extra $80 which isn't too much, but I'm afraid if I take apart the engine that much(remove the pistons and rings), I'll fu<k something up. Dee, is it really that simple? Can I reuse the current rod bearings, or do I have to replace those too if I take the rods off?
2.)should I replace the bearings(main and rod)? Is it something I can do with a micrometer and an FSM? They are relatively cheap if I do it myself, but again, while I'm not a dumbas$ with motors, I'm also not an engine builder!
3.)what about the oil pump? Replace it now, or just go with the current one? Is there any way to inspect this to see what kind of shape its in? I've not really heard of anyone's oil pump going bad... but its not a part I want to cheap out on.
4.)There is some side to side play in the rods. Is this normal? Tim and I were thinking that's where oil drains so when there is oil in there, they don't move, but I wanted to check with someone who knows this stuff. The rods "float" on a cushion of oil, so it has to drain somewhere, and it makes sense that there might be a slight gap for it to flow back out into the oil pan, but I didn't try to move them on my old motor, and its already disassembled so I can't see if they moved either.
Thanks in advance guys:)
Sean
