DrIfT_FoReVeR »
https://forums.nicoclub.com/drift-forever-u16639.html
Fri May 28, 2004 12:21 pm
ok, oil pressure switch...how the hell do i get it off?
ive been working on it for about 2 hours now, until the sun decided to hate me and go down, leaving me in the dark. now, here is my problem:
i have tried using all kinds of pliers, needle nose, long groove joint, vice grip, needle nose vice grip, regular, robogrip, i even looked for a socket that would fit, but to no avail. anyway, when i grip the pliers on the piece, they get a GOOD bite, and when i go to turn the pliers, they just slip right off the nut piece. my step dad was able to get a better grip than me, and he even used his entire body as leverage, and the only thing that moved were the pliers when they popped right off. now, i have an idea, and i need to have this confirmed...from the bottom, its hell and there is hardly any space to move the pliers around, and when i can finally get them positioned, the pliers and my hands and arms are so covered in oil that it literally takes me 5 minutes to get the pliers positioned. so i figured, id change my oil, which is about 2000 miles overdue anyway, and take off the filter and get to the switch from there, then id have a lot more leverage and less oil and grime all over me and my pliers. is this a better idea, or do i need to stick with going in from the bottom? also, does anyone have any tips or tricks that will be helpful in getting this damned thing out? also, in my futile attempts to break this damn thing loose, i broke off 2 of the plastic pieces that go over the metal contact, so i wouldnt really feel comfortable driving it around.
I NEED SOME HELP! THANKS!
