engine check light
sps14mc
Car: cars, music, traveling
alright this might sound stupid, but i'll ask anyways. my engine check light has been coming on and off for quite some time now and i know i have to get a diagnostic/sensor test done but they are pretty pricey and i just don't have the money with school...i read up on the net however that 95 240 seem to had a problem with cross wirings on the sensors? does that make sense? any help would be appreciated...^_^
Hijacker
Car: '92 240sx Convertible
'94 F-150
is the car making any odd noises or acting funny in any way? my old tempo had a problem with the CEL coming on at random times, but I chalked that up to age and crappy Ford wiring.
sps14mc
the car is just shakey and louder but i need a new exhaust gasket manifold....the car is not smooth as it used to be...engine is a lil louder tho. i miss my baby!!!!
NISTECH
look in the nissan articles section. I believe there are instructions on how to retrieve codes from your ecm your self. get the codes and post the results
ricebike
2002 Quest
2005 Altima
doesn't the local autozone test for car trouble codes for free??? i know they do w/ OBD II w/ a plug-in under the steering wheel, but I dunno about obd I <taking off the pass side kick panel & playin w/ the knob to see the green & red LEDs>
NISTECH
95 240 had an obdII plug near the center console stiking out toward the side of the car. cant remember if its on the passenger side of the console or the drivers.
sps14mc
Thanks guys! Your info helps out a lot...anymore suggestions?!?
ricebike
2002 Quest
2005 Altima
nope, go find out if your ecu/ecm has stored trouble codes 1st...
MikeMurphy
Car: Guess
I have an OBDII 95 240sx and I simply got the flashing codes frmo the ECU. I went to a nissan stealership beforehand and they said it was $80 to diagnose the problem. Turned out it was just a loose crank angle sensor =) Im glad I did the 15 mins worth of work myself.
Do a search on how to get ECU codes, or go and buy an OBDII reader from anywhere. If I remember correctly they only go for $50 anyhow. Some 95s were OBDI and some were OBDII. Good time to find out.
sps14mc
Mike Murphy: that's a nice 240 dude...i went to Nissan and yea the diagnostic test is like $80 or something but it hought they were trying to rip me off so i did not get it done =) thanks for the info..
MikeMurphy
Car: Guess
Thanks =D
Do a search on the method of pulling the codes from the ecu, and fill us in to what it turned out to be.
ricebike
2002 Quest
2005 Altima
no autozone's in your area? free odbII scan
CanadianCoch
Here you go, thank me later, lol
Once you’ve pulled the ECU and located the ‘mode selector’ screw on the side...
Turn the ignition switch to the on position, but do not start the engine. All of the 'dummy' lights in the dash should be on.
Turn the 'diagnostic mode selector' screw on the side of the ECU fully clockwise. The check engine light will go out. Now wait at least 2 seconds, and then turn the screw back to its original position (fully counter clockwise).
The check engine light will then begin to flash the trouble code -
The number of long flashes is the 1st digit, and the number of short flashes is the 2nd digit...
So for example, a code 45 would be:
blink........blink........blink........blink - (short pause) - blink...blink...blink...blink...blink
If there is only one code, it will flash over and over and over...
If there is more than one code, it will flash the first, then the second, and so on...then just keep repeating the codes (in numerical order) over and over and over
Now you have 2 options:
To clear all stored codes and turn off the check engine light, turn the ‘mode selector’ screw fully clockwise. Wait at least 2 seconds, then turn the screw all the way back counter clockwise. Then start the car...
To keep the codes stored, simply turn the key off as the check engine light is flashing and the ECU will keep all stored codes and the check engine light will remain on.
COMPUTER CODES for Nissan Vehicles:
Probable 'trouble code' cause for Nissan vehicles 1984 and later...
11 - Camshaft position sensor
12 - Mass Air Flow Meter Sensor
13 - Coolant Temperature sensor circuit
14 - Vehicle Speed Sensor signal circuit is open
15 - Mixture ratio is too lean despite feedback control; fuel injector clogged
21 - Ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning
22 - Idle speed control valve or circuit
23 - Idle switch (throttle valve switch) signal circuit open
24 - Park/Neutral switch malfunctioning
25 - Idle Air Control Valve
28 - Cooling fan
29 - Fuel system rich
31 - ECU internal problem
32 - EGR malfunction (California models)
33 - Front O2 sensor
34 - Detonation (Knock) Sensor
35 - Exhaust Gas Temperature sensor (California models)
36 - EGRC-BPT valve
37 - Closed Loop
41 - Intake Air temperature sensor
43 - Throttle Position Sensor
44 - No trouble codes stored in ECU
45 - Injector fuel leak (California models only)
51 - Fuel injector circuit open (California models only)
53 - Oxygen sensor (300ZX right side)
54 - Short between automatic transmission control unit (TCU) and ECU
55 - Normal engine management system operation is indicated – this means all is OK.
65 - Misfire detected - cylinder no. 4
66 - Misfire detected - cylinder no. 3
67 - Misfire detected - cylinder no. 2
68 - Misfire detected - cylinder no. 1
71 - Misfire Detected - Random
72 - Catalytic Converter Malfunction
74 - EVAP pressure sensor
75 - EVAP leak
76 - Fuel injection system
77 - Rear O2 sensor
81 - Vacuum cut bypass valve
82 - Crankshaft Position Sensor
84 - Automatic transmission-to-Fuel Injection Communication Line
85 - VTC solenoid
87 - EVAP canister purge control
91 - Front oxygen sensor
95 - Crank Cog
98 - Coolant temperature sensor
103 - Park/neutral switch
105 - EGR and canister control valve (Solenoid)
108 - EVAP volume control
111 - Inhibitor Switch
112 - Vehicle Speed Sensor A/T
113 - A/T 1st Signal
114 - A/T 2nd Signal
115 - A/T 3rd Signal
116 - A/T 4th Signal or TCC
118 - Shift Solenoid/V A
121 - Shift Solenoid/V B
123 - Overrun Clutch S/V
124 - TOR Converter Clutch SV
125 - Line Pressure S/V
126 - Throttle Position Sensor A/T
127 - Engine Speed Signal
128 - Fluid Temp Sensor
sps14mc
Canadiancoch: thanks for the instructions
thanks everyone for the advice...i got someone coming down to help me with the codes n everything...i'll let u know how it goes! take Kare*:D
Fighto78
Sorry to revive an old thread but my friend's 240 that he's been trying to get smog legal is pulling a code 55. Recently it totally turned off on the freeway when he was cut off and he braked hard. He's tried clearing it and according to him it just keeps coming back.
What do you fix when everything "is okay"?!?!
Thanks
NISTECH
code 55 means everything is ok
ZULU
wow this is an amazing thread !!!!!
THANKS EVERYONE.. copy paste to word with codes and print abd store this badboy
