Engine check light - P0181 P0183
tedc
Car: 2025 Nissan Rogue SV
2021 Nissan Sentra SV
Just in case someone else runs into this situation. Check engine light has been on the last few days (been very very cold). Codes P0181 and P0183. Dealership has isolated issue to fuel temperature sensor. The are going to replace the complete fuel pump assembly which includes this sensor. Part will be in tomorrow.
darylzero
Thanks man.
You are the kind of person that helps make Nicoclub a great place!
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
The code is pretty much self-explanatory, so it may be the dealer didn't isolate anything.
tedc
amc49 wrote:
Fri Mar 08, 2019 12:55 am
Tech used a scan tool to monitor actual sensor fuel temp readings. Readings were not right and did not change when car was left outside (very cold) or inside the shop. Tech had to remove the rear seat to access the fuel pump and verify everything was OK with the fuel pump connector and wiring. A possible water short in the connector had to be ruled out.
tedc
Picked up my car today and talked to the tech. Once the pump was out the tech found internal loose connections to connector pins causing the error codes plus a false reading that the fuel sensor was bad. Since the sensor is part of the fuel pump assembly, it ended up being replaced as well. No more engine check light.
Lgb0250
Car: 2018 Nissan Rogue SV
Had the exact same problem with a brand new 2018 with less than 100 miles on it. Went back n and they cleared the codes and said it was just old codes that should have been cleared!! A week later the codes were back. This time they ended up keeping it a week and replacing the fuel pump.
Return to “Rogue Forum”
