Engine Builders Question
ka24det-power
Car: 240SX KA24DET
My SR was running perfect but I just upgraded to a GT3071R so I decided to install head studs and a head gasket before I get it tuned.
I have built several Honda's so I understand the basics.
I pulled the head degreased it and cleaned the mating surface on both the head and block. They where both perfectly clean. I reinstalled the head with a Cometic head gasket and torqued the ARP bolts to spec. I put the crank at TDC and then installed the cams TDC 10 o'clock and 12 o'clock. (11 links between them). Everything matched to the JWT and Nissan manual instructions.
Now the problem, I have 20psi compression on Cyl 1 and 4 / 180psi complession on Cyl 2 and 3.
I checked and triple checked the timing I can't tell what it is. When I took it all apart I left everything in the same order shims/lifters/etc...
WTF, I have a tuning session scheduled for Sunday and I might have to miss it.
Modified by ka24det-power at 10:56 PM 7/23/2005
NISTECH
Your heading for this thread.... kinda..... well sucks. If you could change it I would appreciate it.
As far as you problem goes take the valve cover off and look for an I and a E on your cams. That stands for exhaust and intake respectivly. Are they swapped?
