maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Mon Jul 25, 2005 3:09 am
Everything so far is been done on stock internals with varying degrees of results.
The engine is essentially a race engine detuned for everyday heavy sedan hauling duty that noone has dedicated the time and money it would take to engineer and manufacture the components to make it as reliable at a higher output. Such an engine would not fare well in daily use in a two ton sedan for lack of bottom end torque unless boosted, then there are all kind of issues that must be addressed in the cooling and powertrain after such an engine is developed sufficiently to run on the street.
Got money, lots of it? Go for it!
