tdenardoKAT26 wrote:Where did you see the stock spec bc crank? I'm using all bc internals but the only crank i could find was the bc stroker. He's not having any detonation issues with 24psi on 101? That sounds nice. 101 shouldn't be to hard to find, and for the power sounds worth it.
damne its been years since ive looked up parts for the ka. im almost %100 it did exist but i cant find it. but in doing so im growing fond of that bc stroker kit. it seems that the ka motors flaws for the bottom end have been covered in that stroker kit.
#1 lack of lubrication on crank and rod bearings cylinder #4- solution was to make the crank have individual oil supply for each journal through the crank.
#2 the crank not beeing counter weghted. problem solved by counterweights.
#3 with a stroker kit there will be more stress on the bottom end.... to relieve some of that stress notice that the crank has a better "knife edge" than stock.
im not sure if you have checked with a machine shop yet but to fix what ever is wrong with your crank and counterweight it im guessing you would probably spend 700-1000$. plus pistons and rods another 1000. the stroker kit is 3,000. so the big question is, is it worth 1000 difference to get rid of the lubrication issue on cylinder number 3 and 4, get rid of the counterweight issue, and a decent knife edge and .2 liters and a very strong crank. OR machine the stock crank, save a ton of money, could possibly have oil issues on 3 and 4 (if your doing a rebuild with new oil pump is unlikely) still get rid of the counterweight issue BUT have a crank not as strong as the BC crank? in my personal opinion the benefits of the stroker kit out weigh the 1000 difference. the only down fall is this motor stroked is deffinately not gonna be a 9,000 rpm motor but the power you make down low could make up for it.
