WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Jan 25, 2005 11:25 am
The KA24E does not have oil squirters for the pistons, but it still makes a very good boosted motor. It's just slightly less efficient in the way of piston cooling.
IMO the best way to rebuiild the engine with exception of the machine work, if any is being done, is to sit down with a manual or two and do it yourself. it really isn't that difficult unless you don't have any of your own tools. In which case a professional rebuild would be best. But in the case of a pro rebuild, I would think that they would get all the parts themselves for the rebuild. You should look into that.
From my general experience, a thrust washer is simply a washer that goes under any attaching fastener, bolt or nut, that has a high torque load applied. But I'm not sure of the specifics for the KA24E, hopefully someone will chime in. I believe the expansion plugs are more commonly know as freeze plugs, these are the brass plugs pushed into the side of the block to allow water an expansion relief point if freezing occurs. Again please correct me if I'm wrong. Hope that helps and good luck.
WD
