boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Thu Aug 22, 2013 4:52 am
With Tomei camshafts, this would be much simpler. Tomei, like JUN, has a recommended clearance for the base circle of the camshaft lobe and lifter bucket. You would have to do this process for each individual lobe/lifter, so it it time consuming. To achieve the recommended base circle, one has to adjust (grind) the shim to a size that brings a particular bucket and base circle clearance on the camshaft lobe to the specified clearance. This is a very tedious process and a machine shop would charge a hefty price for such a task. I personally would charge upwards of $500 just for the adjustments alone, so it gives you some idea. I did my own with the help of one of our Aussie members, that pointed me in the right direction. My machinist didn't do anything at all, so when I did a leak-down test before adjustments were made, the engine leaked air like crazy. As for your camshafts, I figure the clearances would be nearly identical @ 1mm clearance.
