doridori23 »
https://forums.nicoclub.com/doridori23-u68081.html
Fri Jul 06, 2007 4:20 pm
If you plan on pushing that GT35 past 20psi do yourself a favor and use 2 Walbro's. Also for injectors that high you will need to look very hard at tuning software/hardware. Most of the time I would recommend the GReddy Emanage Ultimate BUT if you are dropping that much money and power to the ground get an AEM Standalone EMS. For the 850s (a little small for the GT35 honestly) you'll need it and the 32x32 fuel maps are better than APEXi or GReddys 16x16 maps as you can adjust fuel every 250 RPM instead of every 500.
DO NOT PUT AN UNORTHODOX PULLEY ON A FRESHLY REBUILT ENGINE! I have both seen and heard of a lot of #1 cylinder bearing issues due to the solid aluminum pulley. The OEM has a small (2.5mm thick to be exact) piece of rubber between the p/s pulley and the ac/water/alt pullies. This is necessary to absorb vibration. If you are feeling frisky get an ATI Super Dampener from Phase2motorsport.
If you going to use the Tomei PonCams or HKS Fat Lobes get the Lash Killer or Solid Lifter set. Eliminate the hydraulic lame lifters and you can safely rev to 9000 with just Brian Crower valves, springs and retainers. I have never used STech but the BC parts are good and their cost is great. On that subject ditch the cam gears. Stick with stockers as a lot of the adjust ables blow up at high RPM. Even Titan Motorsports doesn't need them, use them, or even suggest them and they are running a 1600 whp 2JZ motor.
Everything else is what I either use or suggest so you look to have done your homework.
