float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Nov 09, 2010 7:48 am
Hard break in regardless. The Diesel oil is great, and it's what I used myself. You definitely DON'T want to use a synthetic oil.
It also depends on what kind of rings you're using. If they're stock rings, the top ring is a Moly-faced ring, which breaks in VERY quickly from what I've found. The 2nd ring is a standard ductile Iron ring, and will take a little bit to break in, but nothing outrageous. The Oil rings are always chrome plated and they don't really "break in" like the 1st and 2nd do.
If you got your pistons from CP like I did, the 1st ring is chrome faced and they are VERY hard to break in, and take some SERIOUS beating on. The 2nd ring will be a moly faced ring and will break in pretty quickly, and the oil ring is standard.
I can tell you with my CP pistons, that I drove moderately till I got to about 2500rpms in 5th, and then floored it till redline, and then let it engine break back down to 2500. It burned oil like mad the first time and I thought, "this is a terrible idea", but I did it again, and the oil consumption dropped drastically. By the 3rd time you couldn't see it in the mirror, but my friend following me said there was still a little coming out of the exhaust. By the 5th run there was no oil burning at all.
When I did a compression test on the motor, all the cylinders were w/in 3psi of each other. I did a compression test the other day, and I've lost about 10psi since then (that was right at 6, very rough, years ago, LOL), and they're all still w/in 3psi of each other (I'm sitting at about 185psi now).
I've got another set of rings that are going to go in the motor, probably this winter, to bring it back up to where it was before. I'll break them in the exact same way I did the others, only I'll prob do it on the dyno instead of an old asphalt road near where I used to live, since going well over 100mph on the streets is never a good idea.
