float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Nov 24, 2004 12:44 pm
Well the oil you pick is partly going to depend on your climate. Right now there is snow on the ground, so I doubt putting 50W is going to be a good idea for me right now. I plan on using a 10-30/20-40 NON-SYNTHETIC. I also plan on beating the hell out of it for the first 20 miles, using a magnetic drain plug, a magnetic wrap on the oil filter, and changing the oil at 20 miles, then again at 200 miles. After that I'll run non-synthetic for one more oil change, and then switch to synthetic.
