QX4ME wrote:Maybe I need to correct my habit. Downshift only when there will be a brake overheating.
I think its OK if you do it smoothly, like for example if you put it in "2" while sitting at a standstill or travelling very slowly at the top of the hill is ok. but putting it into a lower gear while already barreling down the hill, and the car actually jerks as it switches gears, i think thats bad for it.
i been downshifting mine since i bought it with 60k miles and now i have 180k miles
then again it doesnt help that i towed a 4,000 lb car, from sealevel up to 5000feet elevation, with smoke coming out of the A/C vents. That could not have been good for my transmission, which failed about three weeks later.
Quote »A side note: One time I accidentally shifted Altima into reverse when going down on a overpass. Engine stalled. I put it in neutral then started it again. It went on with no problem. I was really scared that time thinking the gear/teeth would be all busted. To me, Nissan's transmission is so solid.[/quote]Ive done that too, didnt see any negative effects immediately after
