Engine/Brake Conversion
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
odpl_Razor
I want to replace the stock E1 engine w/ 4 speed column shift gearbox to A14 with 4 speed floor shift or maybe L20B
anyone done this sort of conversion? what do I need to do/modify
Also whats a good front disk conversion? an easy one for now...
odpl_Razor
Anyone tried converting the front brakes to disc?
Would the front brakes off Datsun 1600 (510) fit the front of the NL320?
any other combination that are tried and tested?
odpl_Razor
I've heard of 720 front disc a straight swap for the 620s with balljoints
IMH
I have a J16 (now hard to find, I understand) and a dogleg type 5 speeed along with a  3.889 roadster differential in my 320.  Wasn't too difficult, you just need to round up the right parts, fabricte a trans mount, and have a driveshaft made.  I have seen an NL320 that comes to the local Datsun/Nissan shows with an A14 and 5speed.  Don't really know the details of his conversion except that he has the GX twin SU intake.  None of those brakes will work without modification and fabrication.  I had the 620 disc brake a attending pieces in my garage for years and finally gave up on the project and sold them.  There is someone on this site that is working on a 520 or 521 disc brake conversion.
odpl_Razor
there's heaps of A14s here in australia than J or E series engines
they are a straight swap on B110 pickups I'll probably save my money if I need to fabricate engine/transmission mounts and drop in CA18DET or SR20DET
Is it true that Datsun B10 front brakes are similar to 320s?
IMH
[user=124]Razor[/user] wrote: [quote]Is it true that Datsun B10 front brakes are similar to 320s?
[/quote]Don't know but I wouldn't think so.  They look kind of small and they're 4 bolt.
odpl_Razor
have a look at this
http://members.iinet.net.au/~dattoman_1 ... brakes.htm
only the pcd holes would be different but you can do the rear later
I'm thinking of disc brakes off datsun 1600 (510) they are little similar might work with caliper bracket
matti
My first 320 came with an a12 in it and a four speed floor shift. You have to change/fabricate your own engine mounts and cut the sump and weld it shut to get clearance off the stearing. I imagine that with the sump cut you would have to either turn the oil pickup, bend it or shorten it. Take your pick. The a12 box also uses a cable clutch which means changing your clutch pedle or fitting a hydraulic system to the box. I haven't had a look but the a15 has the forward engine mounts I think which should bolt in reasonably easy (again with the sump done). A ca20e would probably be a good way to go. My opinion is get a donor pintara wagon. They're cheap and if it needs rebuilding ie rings and gaskets you can do all this yourself for around $300. I did one a few years back. The twin spark however is costly to replace items such as dizzy cap about ($50) and there are two types of dizzy for them (Italian and Bosch) The Bluebird series three has a twin spark in it that isn't efi. You can also import the ca20s engine which is a carbie type. Pintara's are usually found with an auto trans but if you look you will find a five speed manual somewhere. If you are seriosly thinking about an a12 engine we could probably work something out relatively easy. I just mounted one in my morris minor with plenty of other mods to go. I suggest if you don't have an engine crane to get a hold of one as you will be needing it a lot with any engine conversion. Have fun.
Matti
pelon52
HI razor I install a A15gx/5spd in my 320 a bit off cutting,welding,thinking but everything is posible see foto at foto album  pelon52
Return to “Datsun Chat”
