seang »
https://forums.nicoclub.com/seang-u122444.html
Sun Oct 04, 2009 7:40 am
I'm pretty sure you can go wrong with ECU tuning, so like RevD said, do lots of research at this point to educate yourself on this stuff. Maybe you will even be tuning it yourself someday when you know what you're doing. But in the meantime... stay safe from the BS.
*note*, my opinion is that thare may not be alot in the way of power increases in ECU tuning alone. Tuning the ECU is just a tool that complements the mechanical parts of the engine, and therfore can only optimize those parts so far, and any increases beyond that static limit will need; hotter cams, better flow, better exhaust, intake manifold, etc... The VQ40DE is already pretty hot stock, so IDK what a different tune would actually net you all by itself. Good luck with your pilgrimage!
