Engine Bogging
ForsakenTH
Car: Nissan S14 Zenki
95 Nissan 240 SX SE. 5spd. I think it has VLSD but after my last few races i have come to question whether it really has ABS and VLSD. I race the car about once a weekend.
Problem: Every time i give the gas more then 10% throttle, the motor just bogs and revs very slowly. i could floor it and the tach barely moves. at first i thought it might need a tune up so i changed the fuel filter and replaced the spark plugs with NGK IX Iridiums gaped to .04. This did not solve the problem and now i am stumped.
Recent car work: Besides the Fuel filter and plugs i replaced about a week ago, i also added a cat-back exhaust with 80mm piping (HKS Hi Power), and replaced the Reverse Switch that was faulty. I also added an Ebay Intake that had to be jerry rigged to the Intake manifold. The pipe was smaller then the coupling so i expanded the pipe diamiter with electrical tape. I also added a B&M short shifter.
Type of Racing: I do a mix of both Autocross and Drift. Almost every weekend sence the start of May. I change my oil after 3000mi or every three races...whichever comes first. my fuel gauge broke about two weeks ago from drift...but i was expecting that.
Area: Erie, PA
if you need any more info or pictures let me know...i hope you can help me cause its really starting to bother me.
s13sr20chris
that intake sounds suspicous. try spraying your whole intake system with carb cleaner while the engine is running and look for the rpms to change.
mighty_18_mike
Car: 1989 240sx
Hey i also have a problem like that but on my 90 240sx 2.4 sohc. I also put a cob job filter off ebay on it and it was a lot of my bog problem. I still have the slight bog and i have been racking my brain trying to fing the problem. If any one has an answer please let ous know. If i find the problem i will post. Thanks Mighty mike
ForsakenTH
hum...i still have the stock intake so maybe ill try putting that back on and seeing if it helps.
