When examining the data with a graphing OBD2 scanner, I notice the following:
- No permanent or pending codes (including running lean) per OBD2 - no CEL
- Short term fuel trim is pegged at 25% (indicating ECM is compensating for a lean condition)
- Load percentage is reported at 100% during the bogging condition
- TPS is reporting correctly at tip-in and wide-open throttle (WOT) during operation
- O2 is reporting at near 0.1V during the bogging condition (confirming lean condition)
- NGK spark plugs, < 1K
- NGK spark plug wires, < 1K
- Fuel filter, < 1K
- Distributor and rotor, < 10K
- New primary catalytic converter, < 10K
- New exhaust manifold gasket, < 10K
- New upstream O2 sensor, < 10K
- New water pump, < 1K
- New thermostat, < 1K
- New radiator, < 1K
- OBD2 - no codes, pending or otherwise
- Catalytic converter test (inlet temperature is always lower than exhaust temperature), both primary and secondary
- Exhaust pressure seems fine when brake torquing engine (no constriction at the tail-pipe)
- Blow-by (none, checked by removing oil filler cap and subjectively feeling for air)
- Alternator voltage, 13.1V
- Mass airflow (MAF) readings, idle and 2500rpm consistently within FSM specifications
- O2 upstream, voltages consistently within FSM specifications
- O2 downstream, voltages consistently within FSM specifications
- Able to go into closed loop based on O2 data, OBD2 shows switching occurring during operation
- Engine coolant temperature (ECT) sensor, responding normally and consistently during temperature rise and fall
- Throttle position sensor (TPS) is correctly and consistently reporting
- Spark is strong with the new plugs and wires
- Rear wheels rotate freely without dragging
- Fuel injector ohm readings
- Actual compression test for variance between cylinders (don't expect anything seriously wrong due to lack significant blow-by air)
- Fuel pressure test, unfortunately do not have a gauge for this (yet)
Your thoughts would be appreciated.
