troll's 240sx »
https://forums.nicoclub.com/troll-s-240sx-u27176.html
Thu Nov 24, 2005 12:29 pm
Ecu was tuned for these specs, base timing was done tps disc. and everything. Anything could be a possibility, plugs were NGK iridium but I dont know if are the correct range though. Gas was freshly pumped in and yea I know the gauge is a POS, but better than nothing. My fuel pump was a walbro, and the reason for the SAFC was because it you ran it hard then engine wants to rev to redline when your coasting, until the engine cools down. Still didnt fix the problem but fixed the rich idle though, I figured it needs to run rich anyways at boost so I just adjusted it for idle.
