disturbed.) »
https://forums.nicoclub.com/disturbed-u15338.html
Tue Apr 12, 2011 3:07 pm
recap: got ahold of some tools but not a bore scope to check pistons for marks, compression 30psi each cylinder
got a good look at the front of the cam gears while checking compression
NO OIL PROOF LOCKTITE or any for that matter ON ADJUSTABLE CAM GEARS.
the retainer bolts had backed off and the cam gears were slamming back and forth in the adjustment tracks. put them back where the wear marks were knock went away. Still wont start, now the compression is only at 60psi so either they are not adjusted correctly from eyeballing it, or (and im assuming this is more likely) that when the gears let go, it got so out of time it slammed and bent the valves. So yeah time to clean out the other head and buy a new gasket cause even though I havnt seen damage to the piston tops my valve train is probably wrecked. hopfully find a scope tonight or tomorrow so ill know whether it just needs to go to the shop to have the gears tuned in. ive heard the bc272s are off a bit when using fidanza cam gears so ill let roberts imports of louisville do it. unless there is another shop in the louisville area any1 would reccomend
