Engine blocks from factory....
datsunboy
Car: Datsuns
Is anyone else's block painted on the INSIDE from factory?I know some builders do this when building an engine, but do they also come painted factory?
reason being I pulled the sump off, and saw mine is painted, and also has "ATS 1" written in black on the block sump gasket surface????
any idea's?
cheersDan
datsunboy
Car: Datsuns
someone must've taken thier sump off before around here!???
NeedCAforS13
Car: CA swapped S13 coupe
explain or take pictures!:) I took apart both my motors but didn't notice anything... granted this was the first motor I've ever disassembled, so I don't think I would notice anything different...
Sean
datsunboy
Car: Datsuns
take pictures of paint?you wouldn't be able to see much at all, because it's black paint, and the motor is still in the car, in a darkish garage.
I don't see how pictures would help anyway.....it's just a question of wether anyone elses engine blocks have been painted on the inside?
NeedCAforS13
mine was brown-ish...:confused:
you tell me if thats painted I guess!
Sean
float_6969
Not paint. Oil coaking. When you get your block cleaned it removes that. I think running some Mobil 1 Delvac 1300 through it would help also. Thats what I'm going to use in mine for the next oilchange or so.
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
all the ones we have dismantled never seen an internally painted block ..yet :)
datsunboy
Car: Datsuns
it definately looks like paint....it is black black....like not oily black, and it is on the bottom of the block too ( where the liquid gasket goes ), which looks like brush marks to me.
anyway....any idea on the "ATS 1" thats written on it?
float_6969
elifino...
