engine block painting
biosehnsucht
I got some high temp paint to paint my block (Since it was tanked it has no paint to protect from rust) and noticed that it said to let it air dry for 16 minutes then either bake in a non food oven for 16 min or to run the engine, or the paint might not stick. So I've no way to make it set, it says if it goes more than 8 hours before the heating process it won't take either, that it could even come off just handling the motor.
Anyone know if its necessary? or if I even need this stuff? I forgot what its rated for but its something like 700-800 or so, they also sold something that was like 300-400ish or something less and then normal ****.
Anyone who has painted their blocks, comments?
cortina-mk1
Car: GT-R Skyline, MK1 Cortina's
just VHT engine enamel will do the job fineyou dont need any better than that unless you want to use a 2 pak type clear over base paint
NeedCAforS13
Car: CA swapped S13 coupe
I used that flat black BBQ paint... still looks nice today
Sean
CA19DET
biosehnsucht wrote:Anyone know if its necessary? or if I even need this stuff?
if the paint manufacturer says so, it probably is...
you dont need it... but its a nice touch
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i used that stuff and didnt let it dry properly. it really does flake off really freaking quick. it sucks too because its ceramic and it gets in your skin and stings like a little bastard. just use some house paint or something. that hi-temp stuff blows.
- tim
redamnavit
I've seen people heat up the barrels of motorcycle engines with a blowtorch to get them up to temp for paint application. Keep the blowtorch moving and that should be fine.
biosehnsucht
In that case I'll get some normal ****..
