Engine/Belt Whining?
cookies69
Car: 2006 Infiniti G35 Sedan :)
I have a 2006 G35 Sedan AT. Around 57,000 miles. In the last week or so I notice after a few miles of driving a sort of whining comes from the drives side of my engine bay. If i shut off the car and turn it back on, it stops. The whining is noticeable at any speed and idling at lights or in park. Any ideas? Thanks :D
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I honestly don't knw much aboout the VQ's but have you check ed the tension on yoru belts? might be time to tighten or replace the accesorry belts, and it could also be an ideler bearings, or even the alternatopr, ps pumps etc
cookies69
I opened the hood and it sounds like its coming from the belt. But, my dad said it could be the alternator. Why would it be acting up? I have no starting problems and if so, this should be covered under warranty correct?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
its not your alternator, its the belts. Just tighten it up. You need to loosen the nut on the idler pulley then 1/4 or 1/2 turn will probably make the squealing stop.
If the belts are cracked you should just replace them. Not expensive...but probably good enough to just tighten the belts at 57K miles.
cookies69
Thanks man, That is good to hear. I'm having my oil changed Wednesday, do you think the infiniti dealer would charge just to tighten it up?
tollboothwilley
they will charge you for sure. LOL
if you do it yourself it will only take you like 5 min. Mostly just the time it takes to jack the car up. If you live in Las Vegas you can stop by and I'll help you out. haha
cookies69
Okay sounds good. Never had to do it before so I was curious. Haha, itd be a mighty long drive to las vegas from... Florida. :P
Thanks for the offer and advice guys. :)
tollboothwilley
haha, yeah it'd take a while to get here for a 5 min job :D
do it yourself, its easy
