Engine Bearings
tonis56
Car: 04 Titan Crewcab
Ive done all my measurements as per the FSM. I have found that I need all new main and connecting rod bearings. I have found quite a few different places to purchase from as well as a few different brand. First is King bearing (found on http://cgi.ebay.com/JDM-NISSAN...wItem). Second is ACL calico coated main and con rod bearings for $200http://cgi.ebay.com/ebaymotors...%3AIT . Third choice is OEM from Phase2. Ive found all those for roughly $150. My question is, Has anyone had experience with these aftermarket bearings? Or would my best bet be just OEM from phase 2. I also noticed that phase2 is the only place that allows me to select the different grades and I know what grades I need. What do you think?
tonis56
bump
DawgMode
Car: 180sx
or u could just do wat i did and by bearings from your local nissan dealership for $30
SmithSR
Car: 240sx
If you're going to order from the internet, order from Phase2.
Phase2 or dealer.
ILikeMy240sx
Car: SR Power
You might get a tighter fit if you select OEM different grade sizes rather than selecting one std size for all main and rod bearings.
For connecting rod bearings, I selected the bearings using the numbers on the crank and the clearance was smack in the middle of the range of allowable clearance.
For main bearings I did the same method (#s on the crank) but I could not get a plastigauge to measure the tight clearance required by the factory standards but mine was well below the limit but a bit out of the std clearance limit which is still ok.
I ordered mine from hybridynamics.com. They have been very helpful and shipped ultra fast. I ordered Monday and got it on Friday. DO NOT order from Midway Auto. They suck donkey balls and took about a month to send me my bearings and everything was sent in wrong quantities... Because of them my rebuild has been delayed for a month. Those sons of biotches....
tonis56
SR_Smith wrote:If you're going to order from the internet, order from Phase2.Phase2 or dealer.
So if i order from the dealer, do I just order for the sr20de from the sentra?
tonis56
ILikeMy240sx wrote:You might get a tighter fit if you select OEM different grade sizes rather than selecting one std size for all main and rod bearings.
Ive also checked into hybridynamics.com and I am pleased with some of thier other parts. Do you know anything about the main bolts that they sell??
tony-
tonis56
I ordered the thrust bearings and the nismo main cap bolts from hybriddynamics. Im looking forward to getting them. thanks for your help guys.
tony-
tonis56
I also have one more thing to add. I am going to be using eagle rods. This wont make a difference on the bearings will it? The journal clearance should still be the same as the stock rod? Correct me if im wrong.
Tony-
Henry G
you should do a build thread.
tonis56
Henry G wrote: you should do a build thread.
Im gonna when I put it all back together! That will be in a couple months when I get the rest of the parts. Cams and Con rods are all I have left.
