engine bay
95hb
Car: 1995 nissan hardbody
does any body know the engine bay specs of a 1995 nissan d21. because im going to put a vg30dett in one . its a 2wd. the engine is710mm long, 775mm wide and 695mm high.
jdefelic
Car: 1993 Nissan D21 Pickup
Sweet.
I am doing the same thing, sorta.
My preliminary measurements indicate that it will fit, but the turbo placement might need to be tweaked a little to conform to the truck engine bay. But the 300zx engine bay is smaller than the trucks so the turbos might not need to be moved at all.
But that should be it.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
the z32 engine bay is hour glass shaped. So, the turbos have a crap ton of clearance. However the 2wd nissans do not, lol! Why would you choose such a heavy and unreliable version of the VG? You will have to notch the frame rails and remove the torsion bars to clear the turbo chargers. There's a guy over at another board who test fitted one in a 4x4 and it had MINIMAL clearance between the frame rails and the passenger side turbo. If your un-familiar with the 4x4's they have greater clearance because of the body lift and the fact that the engine sits higher as well. While doing this swap I would also plan for the bigger h233b rear end since your going to need the v6 pickup driveshaft which mates to a larger flange on the rear end. Plus, you can pull one from a pathy with discs and LSD for the added traction needed with this powerplant. All of this is going to require some decent fab work. g/l. peace.
95hb
what year pathy rear end has disc brakes. thanks you had alot of info i knew there would be some fab work so thats not a shocker. and i was planning on doing coil overs any way the reason im doing this is because ive never seen it done and it would be capable of big power
Modified by 95hb at 9:47 PM 9/15/2008
nismopu
1997 Nissan Maxima
Its not so much the year of pathfinder but the package it came equipped with. So, just go to the yard and see what you can find. If your area is anything like mine you shouldn't have a problem finding pathfinders. lol! peace.
95hb
do you know if an xterra axle will work its like an 02 cause i can get one of those
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
The xterra axle will be too wide for a 2wd HB.
nismopu
1997 Nissan Maxima
How much wider are they? I know the pathfinders are only 5/8" wider
95hb
do you know if i could just use v6 hb mounts for the engine cause if not ill have to do even more fab work. AND I DO NOT LIKE!!!!!!!
nismopu
1997 Nissan Maxima
You will have to use the truck v6 mounts. One bolt hole location is different but the boss for it is on the block so all you have to do is drill and tap. I believe that's on the passenger side?
Why do you want to put this heavy and some what unreliable version of the vg in your truck?
Modified by nismopu at 12:03 PM 9/17/2008
95hb
already answered your question because ive never seen or heard of anyone doing it and it is capable of big power
95hb
95hb
95hb
95hb
maybe ill just do an rb25 anybody know about that
nismopu
1997 Nissan Maxima
There's a link just below this thread about an RB swap. Let us know what you decide. peace.
