engine bay noises
ray666
Car: '92 240 sr powered tuned with a neo
Hi,Are their any notorious engine bay noises associated with the ka24de? what i got going on is, what i believe two different noises. One makes the noise all the time. its not a squeal like a belt i thought it might be a pulley? is that possible? the motor mounts are bad and the engine shakes really bad maybe it has something to do with it? the other noise starts when i start up but when i rev past 2800 the noise stops, any ideas? maybe the timing chain or valves? any help would be awesome thx
94_240sx
Car: 94_240SX
1. Upper timing chain guide2. Stuck tensioner3. Bad engine mounts4. Possible bad injector and running on 3 cylinders????
Valett85
Car: nissan 240sx se (93 240sx se and 95 240 sx se)
sounds like you just have a lot of problems. for sure the raddling noise is your timing chain. the others could be a lot of things.
shally2186
Car: S14.5
yea check ur timin chain and ur guard above it..my guard broke on mine but i had no idea how..take off ur valve cover and check it out
94_240sx
Car: 94_240SX
shally2186 wrote:take off ur valve cover and check it out
If you spot any leak from the gasket, get a new one. Also get some sillicone for half circle area. You need it when you put it back on. Get an FSM and make sure to tighten the bolts in order. If you search, you will find what I'm talking about.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
my alternator mounting bolt almost rattled itself off the car once. i kept hearing a noise that i thought was my timing chain about to die, but it ended up being the washer on the mounting bolt rattling around. take a look around while the engine is running and rev it up at the throttle body while looking around to see if you can visibly see anything moving that shouldn't be.watch out for the clutch fan though, that thing hurts like hell.
