evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Sep 07, 2010 10:47 am
just be carefull where you get water
if you pull the plenum be sure to tape off the intake and pipes iwht ductape or somethign to keep water form getting in there, the cop's are another area where you won't want water
the intake cam cover generally leaks itno the cop valley
and yes die eletric grease is fine just be sure you clean the contacts and unplug replug and test to find the ones that decide to be a problem after you touch them (thats just kinda how this works)
