Good thinking Rev, I do remember now hearing about z24i injectors failing. I hear those injectors can be expen$ive, maybe Kiba should do this, zer...rsionReverend D wrote:Z24i? Leaking injectors? Black smoke is unburned fuel. It's flooding out somehow. Is your EGR performing properly?
Oh... it might be the thermostatic heat riser coming off the exhaust manifold. This provides hot air to the intake tract to aid in warm up. There is a little flap that directs air that can freeze up and route hot air even after its warmed up, causing it to run like its out of tune. check thatkibatheloanwolf wrote:Well If it's cool it starts up NO PROB but if I try to start it when its hot It starts the starts wanting to choke itself out and I have to put it to quarter throttle until I see a light puff of black smoke out the rear then it's fine it just idles a bit low
Good points except that Kiba's engine is not MPFI. It a TBI unit with only two injectors, and if they are leaking, you could just take off the air filter and see it plain as day spraying on the throttle plate. No fuel rail either. If there are o-rings on the injectors, its just to hold them nice and snug because air has to move around them anyway.Q451990 wrote:The reason it would "cure itself" overnight is that the fuel will eventually seep past the rings and into the oil crankcase - so change your oil if it turns out to be the problem!
I would get a fuel pressure gauge and T it behind the filter... clamp the return line, and then look to see if the pressure drops off rapidly. Or if you can pull the entire rail and pressurize it while it's still connected to the lines, you should be able to see the leak. Your issue sounds severe enough that it should be pretty obvious.
I'm not sure if the injectors on your engine are side feed like on the 1990's era Q45, Hardbody, Maxima, etc. but if so, you could have a bad lower o-ring rather than an actual leaking injector. In fact this is usually the case. A bad lower o-ring causes flooding... a bad upper causes a fuel leak under the hood.
Ahh... good to know. Scratch all of what I said... except for the bleed down and running rich part.seang wrote:Good points except that Kiba's engine is not MPFI. It a TBI unit with only two injectors, and if they are leaking, you could just take off the air filter and see it plain as day spraying on the throttle plate.
