Engine and transmission installed questions
72nismo
Car: 510 / G35 / Murano
I just swapped my Ka areplaced my stock clutch, flywheel with Fidanza aluminium flywheel and ACT clutch and pressure plate.My problem has to do with vibration. I notice alot of vibration when I shift into the gears and I coast on them before giving the car gas. I had found some bolts on the transmission loose but I tightened them up but there is still noise that was'nt there before.It seems like I hear most of the vibration on 3rd gear.Any ideas of what it can be??
h.240
Car: 1991 240sx hatchback
Make sure the clutch is aligned properly, and the throw out and pilot bearings are in good shape. You said everything is brand new so I can't see there being any problems with the parts you installed, but check those to just to make sure.
