AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Mon Jan 15, 2007 3:12 pm
Wow....
Lots of stuff to look into there.
First thing that hits me is, get rid of that toggle switch and get your cooling system to work as designed. A thermostatic switch is a must, this way it only runs when needed AND you'll never forget to use it.
Hoses are correct - Pressure test your cooling system, make sure you have a new cap and t-stat.
Do you have a water temp gauge?
Is your factory gauge showing an overheating issue?
Engines are supposed to be hot, so "fry an egg" is not a real useful measure.
Water near intake runners could be a blown head gasket - Change your oil, make sure there's no water in it, and flush your coolant - make sure there's no oil.
