4felix20 wrote:i've pulled the distributor and installed it like 20 times..the rotor is perfectly lined up with the #1 plug wire.
i'm gonna go try again.
Dont be too sure on that.. It can be lined up with the # 1 and u will still be off timming... When u insert that distributor, u can be b4 or after that # 1 pin.... One of those is correct and the other is WRONG..!!!
Remember, when u set the # 1 piston to TDC, the rotor should be PAST the # 1 pin... indicating that the # 1 should have already fired and its on the power stroke..
In basic terms when u insert the distributor, is the rotor ABOVE or BELOW that # 1 pin...?? If u are ABOVE it, your one tooth off...
Make sure that rotor is PAST (below) the # 1 pin...
All this is worthless if ur not on the compression stroke... which is a major mess up by lots of people.. (me included)
And by the way, u can be off by one tooth and the motor will crank over but the idle will be very low and mild and will not react too well to throttle...
