engine almost stalled during rain
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
viet510racer
Car: 08 Nissan Versa SL
yesterday was the first heavy rain in a while, i was driving on the freeway as it was raining then exited and came to a stop (idle at 800 rpm), i tried to crack the window for some fresh air (pressing down all four automatic window buttons, the idle went down to about 500-600 felt like the engine wanted to stall then bounced back up to 1000 then to 800, again i press down all four buttons and same thing happened. the engine never stalled completely. everything else worked ok (speakers, lights, etc. wasnt flickering) i drive a 08 sl manual. i have no clue what would be causing this, any thoughts or suggestions on what to do??? sorry for the long post.
Athikerguy4life
Car: 2008 Nissan Versa
you're not supposed to use all four at once. Use one at a time.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
all 4 windows pull a lot of amperes from the alternator, so it will make the alternator want to turn slower. That slows the engine down and drops the rpms.
viet510racer
thanks for the replies, i guess ill be rolling one window down at a time from now on.
Return to “Versa Technical Discussions”
