Engin and drivetrain maintenance
in-graved
Car: 93 j 30t
92 slammed hardbody
Hey guys, and gals.
I have bought a 92 J30t recently with all the maintenance records since new
Ièv read the owners manual, FSM and even the maintenance manual and havent gotten a clear idea on a good maintenance schedule.
when should the ATF be replaced?
Timing belt?
LSD service?
Any and all help is appreciated.
yodawill2000
Car: 94 Infiniti J30
Timing belt is the biggie.
How many miles is on the Belt now ?
I drain and refill the transmission every 30K
Drop and clean the pan.
Replace the Filter screen and pan gasket.
And the LSD, just drain and refill with a good synthetic gear oil.
(Make sure you can remove the Fill Bolt before draining)
:welcome: To NICO !!!
in-graved
Car: 93 j 30t
92 slammed hardbody
The t belt was replaced at 120xxxkm, so im good there.
do the clutches in the LDS need maintenance?
yodawill2000
No
The J30 lsd clutches are sealed.
in-graved
Car: 93 j 30t
92 slammed hardbody
cool. thanks yoda.
