Engaging Low Range 4WD Problems
Flyingdog
Car: 1998 Infiniti QX4
I bought my QX4 off someone who very rarely (if ever) engaged low range 4WD. I don't use it very often myself, but I like to play with things.
I can disengage from High Range without any problems but getting into Low Range or back into High Range is very difficult. There is lots of gear grinding and I end up turnig the vehicle off.
Furthermore, I tried again this morning and after playing with it, I get a clicking sound from the Automatic Transmission/Gear Shift everytime I press the brake when I'm in Park.
Any ideas on where to start?
Pwnin O'Brien
Flyingdog wrote:Furthermore, I tried again this morning and after playing with it, I get a clicking sound from the Automatic Transmission/Gear Shift everytime I press the brake when I'm in Park.
This is perfectly normal. This is the shift lock disengaging, allowing you to shift from park.
Flyingdog
I thought as much. However, why is it suddenly making so much noise and how do I fix it? Is the shift lock up in the lever or down in the transmission?
Any thoughts on the Low Range shifting problem?
Flyingdog
FSM has a section under AT on the Shift Lock. I'll try this tomorrow.
So, what about the Transfer problems ???
Flyingdog
does anyone think this is the answer?
zerothread?id=382123
Flyingdog
anyone?
fueler
Car: 2 Nissan's
2 BMW's
the loud click when you touch the brake pedal while in park, is normal
as far as engaging, you need to make a swift move with the 4x4 stick and give it some muscle when you do it. This is a mechanical lever connected directly to the t-case, not some sissy electronic switch
jdmartin820
Car: 2001 Pathfinder SE 4wd
I have the exact same problem with my 2001, so I suspect it's something inherent to the design. Even in neutral there's ridiculous grinding. What I usually do is put it in neutral, shut the engine, put it in 4Lo and then restart the car.
alexf20c
Car: '00 SE 4x4
there is nothing wrong with the design. all manual-shift transfer cases operate the same way. like fueler said, shift it quick and firm. it's ok to get a bit of grinding.
when you get good at it you can even do it without coming to a complete stop.
Flyingdog
I'll give it a go
Pwnin O'Brien
I just throw the A/T into neutral and just shift it to 4Lo in one swift motion, no grinding and no noises at all.
josephdmartin8
No disrespect, but I don't buy this explanation. I've driven 4wd all my life, all with manual Xfer cases save 1, have owned many different manufacturers including three other Nissan trucks, and have never had a grinding problem between 4H and 4L on any vehicle. I end up having to drop the car into neutral, shut it off, then pop it into 4L to avoid the grinding issue. This isn't right.
