SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sat Jan 15, 2005 9:38 pm
I have the Energy Suspension master kit on my s13 and there are a few drawbacks. If you are at all hesitant, or don't have a press, then pay a shop to do it.
The first and probably biggest drawback are the massive solid tension rod bushings which limit axial movement and can(could) cause binding, which some people say has cracked their lower control arms. Shortly after doing the ES kit, I swapped to Cucso tension rods, so that is one way to get around what could be a problem.
Next are the swaybar bushings that are intended for OEM bars and are useless if you've upgraded to larger diameter bar.
Some say the subrame inserts are no good. A half-a** attempt at fixing/reducing subframe movement. They may be right.
Other than that, the only real tough part are the rear spindle bushings which need to be burnt/cut out instead of pressed.
For the most part, it's a good kit. Old crusty OEM bushings should be replaced. Worth the money IMO.
