Energy Motor Mount inserts
silverspec02
Car: 2002 Nissan Sentra spec V and 2004 Nissan Altima 2.5S
Anyone running them? I'm looking to get some, and was just wondering if anyone has used them on their car. I have an 02 spec v, let me know both good and bad if you have used them, I also saw a weapon r engine damper that I'm considering. I did a search and didnt see anything about energy motor mounts, so let me apologize in advance if this question has already been asked.
ThanksRyan
nametakennow
Car: '06 MINI Cooper S
Mounts are considered a must by many SE-R owners. They drastically reduce wheel hop, planting the front for better grip on acceleration.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Buy them, you won't be disappointed. Afterwards you need to go by the stealership and have them raise your idle to around 950. If not, every time the fans kick on it will cause an annoying rattle because the motor is that much stiffer.
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
My brother had them on his '01 SE...and they were definitely a night and day difference. Definitely pick them up.
silverspec02
RED_DET wrote:Buy them, you won't be disappointed. Afterwards you need to go by the stealership and have them raise your idle to around 950. If not, every time the fans kick on it will cause an annoying rattle because the motor is that much stiffer.
Will do, and I work at a stealership so I stop by one every day. I've noticed my fan kicks on a lot too so that would be a whole lot of rattling. Thanks for the imput guys.
SA240SXCRUISER
Car: 93 240SX, 94 SENTRA, 2000 MAXIMA
got em on my 94 ga16de they do improve ride quality and i dont have to shift as soon but it does vibrate at stand still definitly need to adjust idle.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
Ok, pardon my ignorance, but can you tell me exactly what these things are/do?I've been reading this forum for several months now and have never heard of Energy Motor Mounts.Thanks and greatly appreciated.
silverspec02
Buzzman wrote:Ok, pardon my ignorance, but can you tell me exactly what these things are/do?I've been reading this forum for several months now and have never heard of Energy Motor Mounts.Thanks and greatly appreciated.
energy is a brand they do mostly suspension poly urethane parts. These are inserts for your motor mounts to eliminate wheel hop/make the motor more stiff in the engine bay. Its kinda like the same effect you get from an engine damper, which i am also looking at from weapon r.
nametakennow
The have less flex than the stock rubber motor mounts, so less energy is lost and more is put to the ground (and goes down more smoothly - i.e. the no wheel-hop deal).
NSRG50
Car: 1994 Infiniti Q45 & 1987 Chrysler Conquest TSi
NSR_S13 wrote:My brother had them on his '01 SE...and they were definitely a night and day difference. Definitely pick them up.
. the sentra feltr soooooo much better shifting through the gears
Griever423
Car: 2001 Nissan Sentra SE
I just ordered some myself. I have an 01' SE, so I'm hoping I'll get a lot less slop between shifts.
As far as raising the idle, is this a definate must? The metal shroud around my second fan (the one that comes on with the AC) seems to rattle and resonate producing a funny noice. I suppose the stiffer mounts will make it worse?
