jdmDAvey »
https://forums.nicoclub.com/jdmdavey-u21131.html
Sat May 06, 2006 8:34 pm
We're utilizing all the stock sensors except the maf of course. In fact, we're wiring it up to the stock harness where the ecu plugs in. The hardest part so far has been deciding how to wire up the crank angle sensor. But we got it figured out relatively easy. All wiring should be done, at the latest, tuesday. Then it's a matter of loading the base map and getting it on the dyno. Crappiest part though was the o2 sensor. They, "EMS", kept saying to use a wideband o2. Yet, its not set up for a wideband 02. Just a 4 wire (2 non-polar heater wires, 1 ground, and one signal). They gave a Bosch part #, so I price checked it... and $325 dollars later, I decided to check out other alternatives. Come to find out, with Bosch at least(I called 3 different Bosch techs)... all 4 wire 02 sensors are the SAME!(As far as their basic design goes). They all read a 0-1v reference. The only differences are different style tips, and different outer core construction. Some are made to handle more or less vibration, heat, and abuse. So we're going with the Bosch universal 4 wire... much, much, much cheaper.
