Do you have a turbo or just stock ka? i did that with my apexi n1 single and ka. it sounded like ****.perpetual gyro wrote:That's right. if you already have full exhaust, then you'd have to hack it somewhere to throw that cat on.
Personally, I'm going the easier route. I had my local muffler shop make a custom 2.5" cat-back, and I threw an Apexi N1 muffler on the end. I only paid $70 for the custom piping and $100 for the muffler, as opposed to paying over almost $500 for the Apexi N1 exhaust.
and now i'm taking off my cat and bolting a test pipe on (hollow pipe) in place of tha cat. So when I need to take the emissions testing, all I need to do is just bolt the cat back on in place of the test pipe.
Of course, this is before i'm getting my headers.![]()
b240 wrote:Do you have a turbo or just stock ka? i did that with my apexi n1 single and ka. it sounded like ****.
perpetual gyro wrote:I have the KA. If you have a KA, then getting the N1 is pointless. You don't need 3" piping on a N/A engine. It actually robs you of some performance by creating more back pressure. 2.5" is plenty.
b240 wrote:Hey black240 when are we going to have a socal meet. Im going out to OC monday and tuesday.
Black240 wrote:I think you have the right Idea Bruinbear. you can replace the fake cat with a real one and still have the headers. BUt I don't know if it will still pass emmisions...???
See this is what doesn't make sense though. Since the diameter is larger, the velocity doesn't need to be as great in order for the same rate of volume of gas to be exiting the exhaust. So slower velocity doesn't neccsarily mean less power. So what is eating power then?EZcheese15 wrote:So then the exhaust velocity decreases. Which means less exhaust exiting the car per second. Which means less air coming in the engine per second. Which means less power.
perpetual gyro wrote:See this is what doesn't make sense though. Since the diameter is larger, the velocity doesn't need to be as great in order for the same rate of volume of gas to be exiting the exhaust. So slower velocity doesn't neccsarily mean less power. So what is eating power then?
EZcheese15 wrote:If the exhaust velocity is high (which is want u want), then it creates a vacuum behind the exhaust, up near the exhaust valves, helping to pull exhaust out of the engine.
If the exhaust velocity is too low, it is true that the same amount of volume of exhaust is leaving the system (larger diamter + less velocity = same volume). However, because the exhaust velocity is low, there is no vacuum created behind the flowing exhaust to help pull the exhaust out of the combustion chamber.
perpetual gyro wrote:Thanks for the explination bro, but I'm still struggling with this concept of how this vacuum is produced with the smaller diameter piping. I am a menchanical engineer at Georgia Tech, so I need to dissect the mechanics of everything.
