hannman »
https://forums.nicoclub.com/hannman-u234601.html
Mon May 18, 2015 8:10 pm
Obviously it's best if we all have our cars running as clean as possible. If your O2's are shot and dumping fuel as a result of a lazy signal, the best case scenario for you is to fix the problem, get your car running tip-top and move on.
If it were my car I would suggest swapping the O2 and testing to see where I land. I have no idea where you live, what the cost is for a re-test or even what Mod's you have on your car. If you have a boat load of other mod's (EGR delete, BIG Cam, Big injectors, stand alone with custom tune etc) you're probably gonna have a hard time passing the proper way. If you're close to stock, with an exhaust, an intake, nismo injectors, 2860 or 2871 turbos and an off the shelf tune from JWT, ASH or Z1, you should be able to pass a smog test without too much hassle.
If you test after replacing your O2's and pass, you have piece of mind that all is well and you don't have to worry for the next round.
If this car is your DD and your registration is expired and you NEED to get this done, I'd say throw everything but the kitchen sink a this thing and get it over with.
All alcohol based fuels are corrosive. They absorb water quickly and will eat away at rubber seals. An 80/20 mix of methanol or ethanol isn't going to kill your car though. In Ontario I think the gas stations have up to 15% ethanol in the fuel that comes out of the pump. Methyl Hydrate or methanol is used as a fuel stabilizer. It's used in various mixtures in race cars, drag cars, dirt bikes, airplanes… It's been used for decades. Do some research.
It WILL help you pass your SMOG test but you SHOULD NOT allow your Z to sit for any extended period of time with a high concentration of methanol in the tank.
Report back so we know how things went.
