Alfador »
https://forums.nicoclub.com/alfador-u28926.html
Fri Sep 22, 2006 2:10 pm
This is the same problem I posted a while back in this threadhttp://forums.nicoclub.com/zerothread?id=153586
I bought the EGR solenoid (cost me about $100 for just the part) and the damn thing still fails. As a matter of fact the NOx went up
Old info (GPM):HC - 0.57CO - 8.99N0x - 3.63 (the limit for this was 3.0)
New:HC: 0.51CO: 10.016NOx: 3.376 (again, limit 3.0)CO2: 353.94 (no limit, but they tested anyway)
The CO did go up a few grams but I'm not sure how significant that is, and the HC stayed about the same but I'm pissed that after that the damn thing went up.
Okay, now something else that has become apparent to me since then is that the person who had the car before me did 1 very stupid thing (well perhaps several but only one that matters here). He didn't do a good job mounting the injen intake, and as a result there is a gash in the pipe worn from vibration against the radiator . I Have since taped this off temporarily but could that be responsible for this problem since the holes are behind the filter and MAFS?
Also as you mentioned before about the exhaust as you mentioned before, I am hesitant to address this just yet but if a lack of back-pressure does appear to be the actual problem would it work to get a silencer or two (double tipped exhaust) and put them in just for the test? I'm sure I could find one that robs enough flow to restore the backpressure if thats the real problem. I'm trying to get pictures of the exhaust and intake but I dont really have access to a camera right now. Thanks in advance.
EDIT: I forgot the title rule, so if someone could change it to match I'd appreciate it thanks.
