Emission test failure help
qsiguy
Car: 1994 Infiniti Q45 Turbo
*I also posted this in the IOM section but I'm in a bit of a hurry for help so I thought I'd stick it here as well. Sorry for the double post but I didn't know how many people check the IOM section.*
Went to get my '94 G50 tested this morning and it failed. Here's what the readings were.MA
Hydrocarbons (HC) in grams/mile *FAIL*my reading 2.20 / allowed .80
Carbon Monoxide (CO) in grams/mile *FAIL*my reading 76.77 / allowed 12.00
Oxides of nitrogen (NOX) in grams/mile *PASS*my reading 0.12 / allowed 2.00
What should I check for? I do have a stage 1 NICO ecu and this is the first test since it was installed. Could this be an issue? I do have the original ECU still, should I just put it back in and see if it makes a difference or should I check some other things first?
One thing I've noticed lately, I've been looking for a good vacuum source to check MAP and haven't found one yet. At the EGR valve I only get a small vacuum when giving it a little gas from idle. At idle, constant higher RPM, or increasing RPM if not from idle doesn't provide any vacuum at the EGR valve. Is this a problem. Seems like there should be more vacuum there. Also, I don't seem to have vacuum at the fuel canister. FSM says I should have vacuum above 2000 RPM but I don't seem to be getting anything. I haven't noticed any vacuum leaks nor can I hear anything leaking. Where's the best place to check the vacuum pressure.?
Plates expire end of the month, any assistance would be appreciated. Also, I'm scheduled to get my car on the dyno tonight, should I try and reschedule until I get the problem resolved?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check your O2 sensors.
EGR only works under steady cruise.
I suppose it is possible that KS failure could overrich the mixture, but just a guess on my part.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Keep discussion here...zerothread/245289
Q45tech
MAF, O2, coolant temp sensor, cats are where to look. In that order.
Not warmed up enough, fast idle at 2,000 rpm until the very last second.
Were those readings from idle or how was 2500 rpm portion?
Don't you have to take it to a shop for repairs and then they must sign a document showing what components and cost they replaced to bring into conformance?
