Ikera »
https://forums.nicoclub.com/ikera-u133587.html
Sun May 31, 2009 5:35 pm
I live in Vancouver, BC (Canada) and we have this thing called "AirCare" that I have to do every year (They test the emission of the car). Needless to say my car has failed the same day new Catalytic Converter was installed. I drove around for about 30min before the test to make sure the Cat is heated up and works at it's best. But it didn't help, does a Cat have a breaking-in period where it's starts to work, aside from warming up?
And here are my results
Driving TestHydrocarbons (HC) 89 PPM (90 MAX)Carbon Monoxide (CO) 2.86 % (0.76 MAX)Oxides of Nitrogen (NOx) 32 PPM (1117 MAX)
Idle TestHydrocarbons (HC) 111 PPM (108 MAX)Carbon Monoxide (CO) 1.44 % (0.82 MAX)
Fuel Consumption is also pretty bad 11.5L/100km
As you can see my (NOx) Is really REALLY low, average car has reading of 325 ppm and my has reading of 32 (10 times lower then average)
And my (CO) reading is really high, average car has reading of 0.07% my car has reading of 2.86 %
I came up with a crazy solution aside from changing O2 sensor and Cleaning the throttle, is to ADVANCE the s*** out of TIMING. Make it the engine run on pre-detonations that would raise the NOx and lower the CO and HC.And after I pass the test change the timing back (retard it).
So... how dangerous is it to excessively advance the timing?
Or do you guys have any other ideas how to fix my emission and get better fuel consumption rating?
Anyone from Vancouver, BC aside from then guy with a screen name "vancouverbc"
