amolao »
https://forums.nicoclub.com/amolao-u11541.html
Tue Nov 29, 2005 4:21 pm
Found the problem, but thanks for the assistance. I will answer your questions and post my solution for the sake of future searches.....The car was stalling at all times when I let the idle down. I will start the car again and it was doing the same...I started checking all vacuum lines, I found a post during a search from somebody that wrote: "To have vacuum you gotta have timing" , this guy is my hero, because based on that and if it works viceversa I found the line between BTP valve and EGR control had a big hole (very hard to detect the way is routed). Well replaced the line and the car started running like it was out of time, It was ...since my last timing chain job I was never able to set the car to the correct timing. That was the reason, the bad vacuum line...I set the timing correctly and the car runs top performance...like never before. I hope this helps somebody...and again thanks...
