Emergency smoke got pulled over help!
ESPER
:eek: hello, car is 95 240sx, 102,000k, ka24de, oil leak from rear engine oil getting fixed in 1 week appointment. Last week, i added 1 container of oil, then for abot 15 secs after driving for about 1 hour, dark grayinsh smoke comes out of exhaust, now today, added another can, after only driving for 5 minutes, LOTS of smoke coming out i am covering ENTIRE FREEWAY!! it ususally happens after accelaeration it seem, so there are times when its normal then all of a sudden LOTS of smoke comes out, so its not constant WTF is wrong??? thanks to all who reply!!
C-Kwik
Run a compression or leakdown test. Check your plugs for any oil fouling.
ESPER
k, if there are any oil fouling on plugs where would it be leaking from?
NISTECH
rings or valve guide seals. typically a valve guide seal causes the smoke when you let off the gas after sustaining a steady speed for a short time then give it gas again you will get a few secs of smoke then it will clear up. Rings are usually more profuse and the smokeing lasts quite a bit longer.
ESPER
well i am checking evertning out and it seems that maybe it could be that i had too much oil in my engine so i drained and i am gonna test it out tongiht, thanks guys!
NISTECH
yea that could definitly cause it....lol
ESPER
hehe ok it was TOO much oil, dayum, i was over compensating for the oil leak i am gonna have fixed, thanks for teh help guys!
