texasoil wrote:What the guy is sellin gon EBAY is a 'resistor' that replaces the coolant temp sensor, fixing it at less than 174F.
MAF are automatically self correcting for air temperature--they are measuring the MASS flow, not Volume flow. THE ECM needs MASS flow of air to set proper fuel flow rate.
Last time I checked , the only IAT ( Intake Air Temperature) Sensor on the early Q45 was in the MAF.http://cgi.ebay.com/ebaymotors...wItem wrote:
....ALL YOU DO IS INSTALL IT IN YOUR IAT SENSOR!....uses a resistance value of 4,500 ohms to override the sensor and signal the computer that it is receiving air at an optimal temperature of 62 degrees.
If this is incorrect, please explain.http://en.wikipedia.org/wiki/Mass_airflow_sensor wrote: A mass airflow sensor (MAF) determines the mass of air flowing through a conduit. This is generally achieved by using heated wires in the airstream. By knowing the temperature of the air (generally through an intake air temperature sensor) and the resistance in the wire, the MAF can determine how much mass is flowing.
