DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Feb 07, 2005 9:39 pm
A really bad O2 sensor would be no worse than a cold brand new sensor when the car is first started. Rich, yes, but nothing like that. Same for O2 being way high (same thing as not working, isn't it?) and timing shouldn't be out of whack with what was done (don't think O2 affects timing). I'd be certain it was a pinched seal except there aren't any other symptoms. Maybe it is indeed a clogged cat. Do a vacuum check on the engine.
